reimomo
Posted 19/08/2010 16:05:19
Last Active: 23/08/2010 21:46:46
Visits: 11
Hi all
I've been using the original SD on my main pc with no problems.
I downloaded the new version to my 2nd pc and picked up my key from the website. Again, no problems.
I then updated my main pc with the new version and I got this error: "An item with same key has already been added". Planning a route, maps, etc are all possible but I can't get TAFs/METARSs etc.
Reading the web page it appears that I need to use the same key that I downloaded for my 2nd pc, so I copied that one and pasted it into the correct folder on my main pc. No joy.
Can anyone let me know how to lose the error message please?
thanks in advance
David
Posted 19/08/2010 16:10:13
Visits: 630
The error you reported was to do with custom data interfering with SkyDemon charts, and has in fact been replaced with something much more helpful in the latest beta release ready for the next public release. I don't think it's anything to do with your activation key.I think you'll need to contact us by email, and then send us the activation key you're using so we can investigate. If it's not letting you get taf/metar then it's almost certainly a stale key that needs to be regenerated.
reimomo
Posted 19/08/2010 16:16:51
Visits: 11
That was quick!
Ok, I've just tried again and now I can get Tafs, Metars etc but I still have my .NET error.
The additional error in the Messages box which said something along the lines of "unable to get data, this is probably due to an out of date key or wrong key" has gone.
If it's just a dud error message then I can live with it, I'll just click continue every time.
But sure I can mail you the key - what's the email addy?
Great program, btw.....
Posted 19/08/2010 17:02:20
Visits: 630
Ok, the remaining error is (I think) nothing to do with your activation key. Does it give you detailed information? If so please post it here.
reimomo
Posted 20/08/2010 13:53:16
Visits: 11
System.ArgumentException: An item with the same key has already been added.
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at Divelements.Aviation.EntityData.Managers.AerodromeManager.EntitiesAdded(IEnumerable`1 entities)
at Divelements.Mapping.Managers.SpotEntityManager`1.AddRange(IEnumerable`1 entities)
at Divelements.Mapping.Managers.PackagedSpotEntityManager`1.Add(EntityPackage`1 package)
at Divelements.Aviation.DataManager.<>c__DisplayClass19.b__f(Object , EventArgs )
at Divelements.Aviation.DataManager.<>c__DisplayClass8.b__7(Object , EventArgs )
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3615 (GDR.050727-3600)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 1.3.2.18776
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Assembly Version: 1.0.3838.18774
Win32 Version: 1.0.3838.18774
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.SandGrid
Assembly Version: 2.2.3.1
Win32 Version: 2.2.3.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Divelements.Mapping
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
Posted 20/08/2010 15:07:13
Visits: 630
You won't see this error in the 1.4 version (a beta of which is already downloadable) but it's occurring because of a conflict, either between a SkyDemon chart and custom data or between two SkyDemon charts (rare). We did just update the Switzerland chart to remove a conflict, perhaps that's what you have installed.
