Posted 18/08/2010 18:14:16
Visits: 630
This question was not about importing a route plan, it was about importing a flight log. Tools -> Import Flight Log -> From File.
malcolm frost
Posted 21/08/2010 19:28:11
Last Active: 10/11/2011 21:17:39
Visits: 35
You need Tools/Import Flight Log/From File
HTH
The Westmorland Flyer
Posted 05/07/2011 10:39:02
Last Active: 03/11/2011 20:06:48
Visits: 45
Resurrecting a truly ancient thread...
I can't seem to open/import GPX files into SD 2.1.2.19729. There appear to be two ways to open GPX and neither are working for me:
1. Click on Open and select GPX file type
2. Click on Analysis | Import log from file.
Option 1 says "The file could not be loaded", whilst Option 2 just does nothing at all.
The GPX file origin is GPSMap 296 > Mapsource 6.13.7 > SD
I know I can import track data directly from the 296 but SD provides no way to select individual tracks, so all I see is a mess of all the flights I've done since I last deleted the track memory in the 296.
If SD could let me select individual tracks or alternatively import the GPX file then that would be a big improvement. I can send a sample GPX file if required.
John
G-JONL - Sportcruiser
Diary of a Sportcruiser kit aircraft builder
Posted 06/07/2011 12:24:37
Visits: 630
Sending us the GPX file in question would help. Both the original from the Garmin, and also the one exported from MapSource.
IkarusC42
Posted 22/10/2011 00:58:40
Last Active: 03/11/2011 20:24:36
Visits: 14
Did you cure this? I'm trying to import a .gpx file (converted from .gdb file in Mapsource) of microlight fields into SD but jus get "File could not be loaded" error. File attached. All help gratefully received!
Ikarus
G-TIFG
microlightsites.gpx
(5 views,
40.04 KB)
Admin
Posted 25/10/2011 13:56:22
Group: Administrators
Last Active: 02/02/2012 10:07:52
Visits: 112
Importing a list of waypoints is different. Click on Waypoints, then Import. The file you posted here appears to import just fine.
IkarusC42
Posted 03/11/2011 18:15:20
Visits: 14
Excellent, that worked a treat! Thanks for the help
Ikarus
G-TIFG
