SkyDemon
SkyDemon Forums
Using The Archos 9
Posted By gaxor 10/08/2010 11:08:17
Add to Favorites0
Author Message
gaxor
 Posted 10/08/2010 11:08:17
Forum Newbie
Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)Forum Newbie - (9 reputation)
Last Active: 18/05/2011 16:27:50
Posts: 7, Visits: 14
9
I thought the following musings may be helpful
I recently purchased an Archos 9 Tablet PC, I chose this device over an Ipad (I am a converted Apple affectionado) specifically so that I could run Skydemon, because so far I have been really impressed with the functionality of this software.
The specific set-up is that I have upgraded to Archos to W7 Home Premium, with some performance tweaks, and a miniature USB memory stick with at least 4gB setup for readyboost to further enhance the speed and performance. GPS functionality is provided by a bluetooth GPS module. The software version at the time was 1.3.1
My first thought was to mount the tablet above the instrument panel, but in my TB10 there was nowhere that didnt obscure at least some part of the instrument panel and/or the radio stack. In the end I lay the Archos on my lap, which actually worked very well.
As a navigation device it works very well, the warnings I felt were useful, and I believe will go a long way to prevent airspace infringements. The altitude readings, whilst I was wary of relying on them actually cross checked with the altimeter to within 10 feet.
Having the large screen made navigation a doddle, and the only criticism would be to the sunlight readability, but that is a function of the Archos, not the software, and by using the tablet on my lap, it was quite easy to either shield the screen with my free hand, or tilt/lift the screen.
Overall impressions were very favourable, and having just downloaded the 1.4 beta, it looks even better with the changes to the display, cant wait to try that out now.
One suggestion, I dont know how feasible it would be, but for a tablet display, it would be quite useful to have some kind of pop-up scratch pad area for noting down clearances etc.
Gary
screetch82
 Posted 15/08/2010 17:26:26
Too Much Forum
Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)
Last Active: 12/06/2011 06:32:25
Posts: 111, Visits: 147
161
hi
have you been able to actually mount this somewhere in the plane? I had the same idea, as it is more powerfull than a PDA or PNA and has windows as an OS. Are you running the normal Skydemon Plan software on it?
Can you charge it via USB or mini USB? This would be essential in a plane as you will only have a 12v power socket the most.
Can you add a screenshow of the archos in the plane?
Using 4.8" WinCe6.0 GPS Touchscreen, NavsGo GO7100 as of March11
gaxor
 Posted 18/08/2010 12:22:48
Forum Newbie
9
Yes mounting was a problem, its too big to windshield mount. In the end I used it on my lap, which actually worked very well. As for the external power, here is a link to the Archos forum, which gives a very neat solution, which also works perfectly
http://forum.archosfans.com/viewtopic.php?f=50&t=34913
Gary
malcolm frost
 Posted 21/08/2010 19:09:43
Junior Member
Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)
Last Active: 10/11/2011 21:17:39
Posts: 17, Visits: 35
17
I have an Archos 9 as well, I've yet to use it airborne, but I have now succeeded in connecting my Blackberry Pearl through Bluetooth and accessing the internet to get Notams, Tafs and Metars without a WiFi connection. I have "unlimited" data through Orange PAYG but I would imagine this data is pretty compact as long as I don't download charts. Probably usable abroad as long as you're careful!
The new Blackberry device manager v6.0 won't work on the Archos, but v5.0 does.
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
