SkyDemon
SkyDemon Forums
NOTAMS
Posted By Steve 09/07/2010 11:18:34
Add to Favorites0
Author Message
pink leader
 Posted 12/08/2010 13:21:45
Too Much Forum
Posts: 435, Visits: 1,560
710
OK. Was probably my fault. But with latest beta version 1.3.3 build2, NOTAM window OK on all 3 mobile devices (8410, loox560 & cheapo chinese)
TAFs & Metars available via Active Sync in loox, via wifi in cheapo BUT no way of getting into 8410 (no web access, Active Sync does not work on 8410).
Not that bothered since iphone app does TAFS & Metars extremely well (aeroweather). But if and when Tim gets more comprehensive wx feed, then this will matter.
Suggest that an option to transfer wx data during card sync wd be v useful  .. once full wx info.
D
pink leader
 Posted 20/08/2010 14:26:27
Too Much Forum
710
Although clock is now reset within SD mobile, this does not seem to be being used by NOTAMs. Synced 8410 via card and booted up. Notams not visible on map.
Turned of & got normal car GPS to get a fix and update clock.
Reloaded SD.
NOTAMs visible.
Any ideas?
D
 Posted 20/08/2010 15:08:39
SkyDemon Team
SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)
Posts: 980, Visits: 630
As we said before, you need a device where the clock is set right in order for SkyDemon to load NOTAM on startup. SkyDemon will now update the clock, but it doesn't reload NOTAM whenever it does so.
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
