SkyDemon
SkyDemon Forums
InFlight renameable .exe file
Posted By JonathanB 01/07/2010 23:18:43
Add to Favorites0
Author Message
JonathanB
 Posted 01/07/2010 23:18:43
Forum Newbie
Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)Forum Newbie - (7 reputation)
Last Active: 26/08/2011 10:35:43
Posts: 7, Visits: 12
7
I've been playing around with getting the demo working on a WinCE GPS device (actually the Airspace Aware device), and one limitation is the fact that the launch .exe file has to have a particular name. It works fine when I rename SkyDemon.exe but then the sync function from the laptop won't find the software properly. I've ended up having to have two copies of the .exe file with different names to get around this.
Would there be any way to uncouple the name of the .exe file from the sync function? Would probably help the app to work on lots more WinCE devices that have similar filename requirements.
 Posted 08/07/2010 23:50:46
SkyDemon Team
Posts: 980, Visits: 630
SkyDemon Plan searches for SkyDemon.exe on the device to determine the installation location. Your idea of having two executables would seem to do the trick, in the absence of a better way of checking for installation location.
Doober2004
 Posted 09/07/2010 10:44:18
Forum Member
Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)Forum Member - (26 reputation)
Last Active: 04/10/2011 14:14:34
Posts: 20, Visits: 103
26
There is a better way to run SkyDemon on AWARE!  Try the following ......
Put inflight onto an SD card using the SD method
Switch on AWARE with SD card removed
Insert SD card once AWARE is booted up to original device menu page
Click settings
On settings page click the arrow (for more options)
Click Nav Path
Click the ...... path box
double click Sky Demon folder
double click SkyDemon.exe file
click save button
close setting page
click GPS button on front page to run SkyDemon
activesync runs perfectly!
NB - reversion to run AWARE saftware is just a repeat of above but select FreedomCE.exe
Click
JonathanB
 Posted 17/08/2010 12:46:31
Forum Newbie
7
Doober, that is an option, of course, but it seems far easier to be able to just swap the SD cards and have it just work!
Tim, all I was wondering was if the software could look for a different file in the installation. Not that it matters much having two copies of the executable with different names (Shame windows doesn't do hard links like unix really!)
 Posted 17/08/2010 16:29:38
SkyDemon Team
There's really no reason why we should look for anything other than SkyDemon.exe, since we're looking for SkyDemon.
Windows actually does both hard and soft links brilliantly, but not (I don't think) on device storage cards.
JonathanB
 Posted 18/08/2010 23:00:47
Forum Newbie
7
I guess I'm thinking from a unix background where checking for library or header files or even md5 checksums would be a more usual way (I think) of checking for a software location. It doesn't really matter though, it's my own fault for re-using kit not designed to run an arbitary .exe filename (although I'm sure there are many devices out there which are the same).
It's a limitation of the FAT filesystems on SD cards that prevents hard linking. I never knew that other Windows filesystems could do filesystem links!
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
