SkyDemon
SkyDemon Forums
Feature Requests - Checklists + Bigger Buttons
Posted By neiloakley 16/06/2010 10:21:06
Add to Favorites2
Author Message
 Posted 27/08/2010 11:41:47
Too Much Forum
Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)
Last Active: 27/01/2012 17:45:23
Posts: 235, Visits: 585
349
Sure - I understand that and it makes perfect sense. It's probably best if I send you some screen shots.
I'll try and explain it though.
Imagine you have a runway showing on the screen (at the default DPI settings) - the text is sized to fit more or less exactly within the runway - so you have the length in the middle and the runway numbers at either end.
If you then double the size of that text, you can no longer see it as it obliterates the underlying runway and all the text draws on top of itself. The runway text itself needs to be excluded from the global scaling if possible.
This is the contents of my XML file:-
Steve
 Posted 27/08/2010 11:46:51
Too Much Forum
349
The device is an 800x480 unit and the actual dpi is 133
 Posted 27/08/2010 11:48:15
Too Much Forum
349
(?xml version="1.0" encoding="windows-1252"?)
(DeviceSettings Dpi="192")
(/DeviceSettings)
(Angle brackets swapped for normal brackets so it will post!)
 Posted 27/08/2010 12:23:01
SkyDemon Team
SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)
Posts: 980, Visits: 630
Thanks, could you possibly show us a photo of the device with the errant behaviour?
 Posted 27/08/2010 15:07:13
Too Much Forum
349
I'll do it tonight for you. I think it'll have to be photographs of the screen as I'm not sure how to do screen grabs!
 Posted 29/08/2010 11:51:55
Too Much Forum
349
Sorry for the delay.
Here you go:-
 Posted 30/08/2010 10:27:14
SkyDemon Team
Thanks, I think we've got it.
 Posted 03/09/2010 07:41:32
Too Much Forum
349
I've just noticed this is fixed in the latest release.
I would just like to say that I have never once in the past come across a software package which has undergone such rapid development and ongoing enhancement as SkyDemon. The responsiveness of the developers is staggering.
I really do wish you every success.
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
