SkyDemon
SkyDemon Forums
Unit Preferences by Aircraft, not Global.
Posted By bsdchapman 24/10/2009 23:14:00
Add to Favorites0
Author Message
bsdchapman
 Posted 24/10/2009 23:14:00
Junior Member
Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)Junior Member - (19 reputation)
Last Active: 27/11/2011 15:15:38
Posts: 19, Visits: 31
19
Currently, the units (nm/sm/km, ltr/usg/imp, kg/lbs, and also hold time) are defined in the preferences for the entire program. As the units of mass/volume to be used in planning depend on the aircraft type (or rather, what's used in the pilots/operators manual), and the hold time changes depending on powerplant, could we have these preferences set within the aircraft definition?
bsdchapman
 Posted 24/10/2009 23:44:34
Junior Member
19
Oooo - Same goes for 'Hide Airfields with Runways Shorter Than...'
derekf
 Posted 27/06/2010 19:10:29
Forum Member
Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)Forum Member - (35 reputation)
Last Active: 03/05/2011 08:29:33
Posts: 35, Visits: 173
35
I'd also like the abity to set units by aircraft.
Also, can we have fuel in lbs (as I have a share in a C310 and that's what the calculations are done in)
Derek...
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
