SkyDemon
SkyDemon Forums
SkyDemon Inflight needs to be able to run on a Laptop
Posted By JamesD 14/02/2010 20:12:50
Add to Favorites0
Author Message
JamesD
 Posted 14/02/2010 20:12:50
Forum Newbie
Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)
Last Active: 10/11/2010 14:20:29
Posts: 3, Visits: 35
3
I fly with a chart, Garmin GPSmap 196 and now my laptop with a sub £30 USB GPS unit plugged into it.
I had decided to spend £1000+ on a larger colour gamin unit. That was before I bought the GPS dongle for my laptop. Using Navbox to create a route, Memory Maps with the route from Navbox and the netbook I already had, I found that the PC could do just what I wanted the colour Gamin to do. Plot my position on the latest charts that were digitally stored in Memory Map when flying. I saved over £1000 and had brilliant results.
Now SkyDemon is here and it's much much better than Navbox and better value. Problem is InFlight doesn't work on a PC (though I bought that as well). I now use Skydemon to plan my flight - it's fantastic for that. But as I don't want to buy yet another PDA or GPS unit, I still have to resort to exporting the route and then importing to Memory Map. Worse as the export from the SkyDemon Plan doesn't seem to be readable from Memory Maps, I first export it to my Garmin unit, then import it from the Garmin to Memory Maps and off I go.
Now that tablets are on their way, with built in GPS, phone, a size manageble in a plane but bigger than a PDA, light and with good batteries surely it makes sense to put InFlight on a PC platform or as a poor substitute have SkyDemon Plan track using the GPS! Surely if you've got the software working on a cut down version of Windows it's not too much a step to run it on Windows XP, Vista or 7. It's a sensible move the only people who won't be happy would be Garmin!
Note I still fly with the Garmin as it gives me a few saftey feature (though I believe InFlight could replace those too).
 Posted 17/02/2010 12:03:50
SkyDemon Team
Posts: 980, Visits: 630
We plan to bring the major InFlight-specific features (moving map, approaching features instrument) across to Plan, and they'll be enabled when a GPS unit is attached. So this will be a great (and very rich) solution to use on a laptop in a plane.
Bill Goldsmith
 Posted 05/08/2010 07:41:29
Forum Newbie
Last Active: 20/10/2010 08:11:08
Posts: 3, Visits: 25
3
I have an ASUS 9" laptop and a blue tooth GPS "22 and Skydemon runs perfectly on this set up
Cheers Bill Goldsmith
malcolm frost
 Posted 06/08/2010 19:20:53
Junior Member
Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)Junior Member - (17 reputation)
Last Active: 10/11/2011 21:17:39
Posts: 17, Visits: 35
17
and I'm running it on an Archos 9 tablet with bluetooth GPS.
pink leader
 Posted 06/08/2010 21:53:51
Too Much Forum
Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)Too Much Forum - (578 reputation)
Last Active: 2 days ago @ 08:54:56
Posts: 433, Visits: 1,555
578
For what its worth, I would be nervous running on a straight windows platform (xp-W7). Possibility / impact of failure is too high in my view. Conversely, WinCE which powers most car GPS worldwide does not fall over very often if at all.
Am going to post my experience of Cheapo Chinese 7" WinCE device in next few days once I have actually flown with the thing and used it properly.
Looks v encouraging (also runs MemMap for those who like  charts).
David
screetch82
 Posted 16/08/2010 16:23:45
Too Much Forum
Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)
Last Active: 12/06/2011 06:32:25
Posts: 111, Visits: 147
161
i cant agree with you. A UMPC running WinXP will have more memory and a faster processor. I have a WindowsCe device and some WindowCE are cut down verisions. Yes you can sync with Windows but it is not a full fledged system.
Using 4.8" WinCe6.0 GPS Touchscreen, NavsGo GO7100 as of March11
screetch82
 Posted 16/08/2010 16:25:17
Too Much Forum
161
plus I have had many CarSat navs and they freeze as often as any other pc does. Plus a PC normally freezes due to software and drivers which have been installed on the operating system.
And you should not use this as your sole means of navigation whilst flying anyways Smile
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
