SkyDemon
SkyDemon Forums
skydemon on 7" a gps device
Posted By dansmusic 11/02/2010 19:26:09
Add to Favorites1
Author Message
dansmusic
 Posted 11/02/2010 19:26:09
Too Much Forum
Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)Too Much Forum - (58 reputation)
Last Active: 14/02/2012 16:56:27
Posts: 6, Visits: 68
58
Hello Aviators
Has anyone been able run skydemon on one of those cheap 7" gps device units you see advertised ?
The units run wince so theoretically it should work right ?
I was just wondering if anyone had tried it , before I spend the £100 on a unit.
Dan G
 Posted 13/02/2010 11:28:38
SkyDemon Team
SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)
Last Active: 09/05/2012 14:51:04
Posts: 1,159, Visits: 724
Which particular model were you looking at? I know somebody had it running on an iPAQ which I think might have been 7".
dansmusic
 Posted 13/02/2010 13:43:08
Too Much Forum
58
 Posted 13/02/2010 15:42:09
SkyDemon Team
Looks nice! Shame it's generic unbranded, there doesn't seem to be any way of telling what make it is and therefore whether people have successfully gotten arbitrary software to run on it. Although the description does say it'll run most GPS software.
13/02/2010 15:42:30 by Tim Dawson
dansmusic
 Posted 14/02/2010 11:11:27
Too Much Forum
58
Yeah Tim my thoughts as well. I think I will just bite the bullet and order it.
If worst comes to worst I might have to wangle around with the sytem registry to get it to launch.
Dan
Tony
 Posted 14/02/2010 22:18:36
Too Much Forum
Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)Too Much Forum - (223 reputation)
Last Active: 10/01/2012 19:18:06
Posts: 33, Visits: 255
223
Dan
Good luck.
I know someone who brought a 7inch Chinese GPS to run SkyDemon InFlight on it and gave up in the end as he could not get the software to work on it. I also brought a 5inch GPS but again, after hours to try and set it up, can not get the software to run on it even though I have had Memory Map running on it with no problem.
Tony
Topcat
 Posted 15/02/2010 18:12:37
Forum Member
Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)Forum Member - (40 reputation)
Last Active: 20/02/2010 12:55:26
Posts: 6, Visits: 21
40
Hi Dan,
I can confirm I have Skydemon working on that very device, although I must admit I'm not 100% sure how I did it.
First you need to break out into wince with CECMD.exe so you can run the .net CAB files directly from the SD card, the skydemon seemed to work after I'd tried both the ARM and x86 versions together, I then deleted stuff until it stopped working and then re-added the last file I deleted. I'll try to post a screenshot of the SD card later when I've a bit more time,
Good Luck,
Topcat.
dansmusic
 Posted 15/02/2010 19:33:23
Too Much Forum
58
Hi Topcat
Thats great news. i though it must be possible to run Skydemon on those units.
Have you had a chance to try it in the air yet ?
A friend at my flying club just bought the new Adventurer Pilot 7000 7" ( £599 )and he isn't even that keen on it.
So if this works it will be an excellent alternative and for the money unbeatable.
Great software and reasonably priced hardware....... Happy Days.
Thanks for the post
Dan
EGSJ G-BOIV
dansmusic@ntlworld.com
Mark Northwood
 Posted 18/02/2010 18:53:35
Junior Member
Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)
Last Active: 10/02/2012 18:15:54
Posts: 1, Visits: 13
11
Hi, Ive got one of these units running. I found no need to do anymore than copy the SkyDemon files onto the SD card - no need to boot into Windoze CE. The screen is not very good in sunlight and battery life isn't great however.
drianwilson
 Posted 04/03/2010 19:51:01
Too Much Forum
Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)Too Much Forum - (77 reputation)
Last Active: 29/02/2012 20:03:35
Posts: 10, Visits: 20
77
I bought one of these units, it works great with Inflight (my GPS is COM2, 4800 baud).
Only problem is it doesn't save my default settings (I am on the demo version) and this is the one thing that makes me wary of purchasing it, as the device was being set up for my slightly non-tech savvy partner who will be a little miffed she has to set the GPS device, orientation etc. up each time.
Have you had the same problems with settings not being saved?
I loaded up on the SD card and it worked fine.
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
