SkyDemon
SkyDemon Forums
skydemon on 7" a gps device
Posted By dansmusic 11/02/2010 19:26:09
Add to Favorites1
Author Message
Steve
 Posted 03/07/2010 10:34:46
Too Much Forum
Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)
Last Active: 06/12/2011 16:27:58
Posts: 55, Visits: 91
63
If anyone buys/uses one of these units I would be very interested in knowing how it performs. It does look like a decent system.
Steve
Aero AT3-R100, C172 Skyhawk, EGBK Sywell
Boeing767
 Posted 03/07/2010 17:22:51
Forum Newbie
Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)
Last Active: 10/08/2010 10:38:38
Posts: 4, Visits: 6
6
I have get managed to use the 7 " GPS device after many hours of trial&error only
to find out, that for me THE DISPLAY IS ABSOLUTELY NOT CAPABLE for inflight use
as the brightness and contrast is MUCH MUCH to low.
When looking onto the display, all you see is black...
Please consider, that for inflight use ONLY translective or (not so good) transmissive
displays are suitable (my mind).
Please don't waste your time trying to get it work only to find out, that for real use
it is useless.
For me, the best device (tested under real conditions) is the pocket loox n560, as it
has built in GPS, quick cpu and a transflective display, that get even brighter, when direct sunlight comes to it.
TaffRich
 Posted 07/07/2010 16:15:36
Forum Newbie
Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)Forum Newbie - (5 reputation)
Last Active: 12/08/2010 20:23:18
Posts: 3, Visits: 44
5
Has anybody managed to instal SkyDemon on to this Device?
 Snooper S7000 from This site:
http://www.satnavcompany.com/productdb/snooper_s7000_uk_i/index.html
it runs memorymap, thanks for any advice.
taffrich
spandude
 Posted 19/07/2010 21:39:03
Forum Newbie
Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)
Last Active: 07/08/2011 20:40:32
Posts: 1, Visits: 16
3
Boeing767 (03/07/2010)
Boeing 767, which 7" screen are you referring to, is it the X10 mid or one of the others?
KevWal
 Posted 28/07/2010 23:17:12
Forum Member
Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)Forum Member - (36 reputation)
Last Active: 09/01/2012 19:31:25
Posts: 18, Visits: 70
36
Can you confirm which device you mean, the first posters generic 7" GPS, or the later poster X10 MID Tablet PC?
Kev
nje
 Posted 17/12/2010 16:16:13
Too Much Forum
Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)Too Much Forum - (233 reputation)
Last Active: 7 hours ago
Posts: 154, Visits: 1,043
233
Good Afternoon, I've been reading the topics with interest and downloaded the trial version for my netbook which I think is excellent. I took the risk and bought this chinese 7 inch unit
http://cgi.ebay.co.uk/7-Inch-GPS-Navigation-4G-Card-CE-5-0-GPS-POI-TTS-128RAM_W0QQitemZ120660676098QQcategoryZ156955QQcmdZViewItemQQ_trksidZp4340.m444QQ_trkparmsZalgo%3DCRX%26its%3DC%252BS%26itu%3DSI%252BUA%252BLM%252BLA%26otn%3D20%26ps%3D63%26clkid%3D5715149187488116868
Skydemon loaded straight on to it, the only thing I had to do was to drop the small file (found it in another post on here, thanks very much) into the folder to make the fonts increase to a decent size. Unfrotunately the time between downloading the trial and ordering and getting my new toy has meant that after just 2 days of receiving it, the trial version has expired. I would like to buy the full version but could first do with some advice from someone who has used the software for real. My only concern is the 're-drawing' . When I scroll along to different parts of the charts it keeps redrawing, does this affect it all when flying, in other words is it constantly and noticeably redrawing when flying. I'm used to using memory map, which doesn't do this, incidentally I can't get the unit to run memory map, but I am not too hot at fiddling with these things. Also for further info, you can go to the wince 5 desktop on this unit, I'm not sure what the benefit of that is, but you can if needed. The screen is very clear (in the car) I fly in a PA28 or Beagle pup so bright sunlight is much of a problem. Your advice will be appreciated
 Posted 18/12/2010 08:31:46
Too Much Forum
Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)Too Much Forum - (343 reputation)
Last Active: 27/01/2012 17:45:23
Posts: 235, Visits: 585
343
The trial version of the mobile software doesn't expire like the desktop version.
Instead, it limits you to 30 minutes use before exiting - so you can still try it in fight despite the expired desktop trial.
Redraws in the air are a non issue. Basically the little plane icon positions itself so that the screen shows more of where you are going. The unit then redraws each time the plane gets near to the middle of the screen.
It works perfectly and I've never found the redraw to be intrusive.
nje
 Posted 18/12/2010 10:08:49
Too Much Forum
233
Thanks for that info (stevelup). It seems to work the opposite way for me though, on my mobile unit it has expired, on the bootup screen it only gives the option of 'exit' and no longer the chance to 'I accept'' and says that the evaluation copy has expired (or words to that effect). On the other hand, the desktop version on my netbook still works OK although it does say that the charts are out of date, and mentions the 'charts manager' but I can't find it.
nje
 Posted 18/12/2010 14:56:21
Too Much Forum
233
Just an update, I've just bought the plan and Nav package so I can now have a play for real, when the weather improves, that is.
KevWal
 Posted 02/01/2011 22:52:36
Forum Member
36
Can you give us any indication of screen brightness and reflectiveness?
If you walk around outside on a bright day how clearly is the screen readable?
About the speed of the system, does it load and refresh ok?
Does the touch screen work only with a finger, or with a normal stylus too?
Kev
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
