SkyDemon
SkyDemon Forums
Sample custom data
Posted By Baron von Mildred 10/02/2010 09:48:35
Add to Favorites1
Author Message
Baron von Mildred
 Posted 10/02/2010 09:48:35
Too Much Forum
Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)Too Much Forum - (115 reputation)
Last Active: 21/01/2012 19:43:07
Posts: 71, Visits: 156
115
Does anyone have a sample custom data .csv file I could look at? I had a go at creating my own data file as per the tutorial, i.e. entering some data in a spreadsheet, then converting it to .csv, but the Skydemon software says 'input string not in correct format'. Just thought if I could see a file that works, I could work out what was wrong & correct it.
BVM
 Posted 10/02/2010 10:14:53
SkyDemon Team
SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)SkyDemon Team - (1,245 reputation)
Posts: 980, Visits: 630
Sure, what data were you interested in? Airfields, obstructions?
Baron von Mildred
 Posted 10/02/2010 13:15:47
Too Much Forum
115
As a first attempt I was trying to make a file for naviads. Once thats successful I intend to start building up the rest of the data for the area I fly (central Africa) i.e. airfields, airspace
 Posted 10/02/2010 13:40:00
SkyDemon Team
Sure. Here's a file with three navaids from the UK data.
 sample.radioaids.csv (13 views, 163 bytes)
Baron von Mildred
 Posted 13/02/2010 10:59:49
Too Much Forum
115
Thanks for that Tim. I give it another try & report back. Sorry its taken a few days to reply, I don't get regular access to internet here in Africa!
 Posted 13/02/2010 11:27:40
SkyDemon Team
No worries. We've actually created a graphical tool that makes it really easy to create SkyDemon data. Would you like to try a preview of it? If so, let me know by contacting me directly using the link at the bottom of the homepage and I'll email you a copy.
Baron von Mildred
 Posted 19/02/2010 15:33:01
Too Much Forum
115
Thanks for the sample thats helped. If anyone else is having trouble with this, the problem was that when I created the .csv file from the spreadsheet it wanted to put commas & quotations around everything. I needed to force it to drop the quotations.
Anyone else having trouble getting custom data to load at start up? Loads fine on import now!
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
