cct
Posted 14/08/2011 12:24:32
Last Active: 05/05/2013 23:00:15
Visits: 218
I plotted a flight from Bourn (EGSN) returning to Bourn, and for some reason I am getting a warning that it passes through Gransden Lodge gliding site.
This was actually created in the full version, where the warning does not appear - it just shows in Light. I have attached an example
Any ideas?
Bad warning.gpx
(10 views,
2.22 KB)
pink leader
Posted 14/08/2011 17:28:07
Last Active: 23/04/2013 21:48:37
Visits: 2,024
Not sure I follow you completely as I have not bothered to view the GPX file. But if you plan a route that passes through a glider site, the Flight Details window does NOT give a warning. But if you flew such a route, then some 2 - 3 miles befors you reach the site, an alert bar will come across the screen. Is this what you mean? If it is, seems fair to me .. same is true of airfields with no CTA etc.D
cct
Posted 14/08/2011 18:45:22
Visits: 218
Pinky - if you had 'bothered' to view the GPX file, you might perhaps have noticed that the course went from Bourn directly away from Gransden Lodge, and returned from the same direction, so to get a bar saying my routes passes through seemed surprising. Also I do not get the warning in the full version, although I havent tries the Webby.
Chris
Posted 06/09/2011 11:47:27
Last Active: 20/05/2013 17:39:31
Visits: 1,175
Thanks, we will check why this is being picked up.
