SkyDemon
SkyDemon Forums
Anyone found a Hi Brightness display ?
Posted By flyingalan 09/07/2011 15:00:32
Add to Favorites2
Author Message
flyingalan
 Posted 09/07/2011 15:00:32
Too Much Forum
Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)Too Much Forum - (165 reputation)
Last Active: 23/03/2012 14:09:38
Posts: 16, Visits: 47
165
Has anyone had any success in locating/using a hi brightness display in the 5 to 7 inch range ?
I have looked at several Chinese devices but they all seem very similar with average brightness and contrast.
Interestingly my 3 year old Navigo 4 inch screen is better than any of the recent Chinese ones I looked at, it seems brightness is not the only issue but contrast has an effect on daylight readability as well. Looking at my Navigo I'm not convinced that it is significantly brighter but the contrast is definately better with whites more white, blacks are blacker and colours more saturated. This certainly helps readability in poor light conditions. I'm suprised that my old device seems better than modern screens.
Asking Chinese suppliers for screen brightness specs seems to draw a blank so its hard to forecast what you are buying and if it will be any better. My guess is that most screens are around 250 nits (cd/m2) and to be worthwhile we need at least 500 nits. I know that screens specified for true sunlight readability are 1000 nits and above.
I'm suprised that none of the available devices I can locate fill this high brightness corner of the market even at a price premium. They must be made as units like Bendix and Garmin are available but only with their software.
Has anyone else had any success in locating a bright screen for use in bubble cockpit aircraft ?
 Posted 11/07/2011 13:23:11
SkyDemon Team
SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)SkyDemon Team - (8,581 reputation)
Last Active: 09/05/2012 14:51:04
Posts: 1,159, Visits: 724
We've located such a screen, and it's in our forthcoming Mobile MD device Smile
It's difficult to buy such devices off the shelf because they have different requirements to car satnavs which represent most of the market for handheld GPS units. You're quite correct that contrast makes a big difference as well as raw brightness. In general I don't believe nit figures that manufacturers quote because they often lie, but car satnavs will usually be 200 - 250.
Legibility of your aviation GPS at lower brightnesses will depend much more on how you mount it than anything else. Units with 1000nit displays can reasonably claim to be legible at virtually any mounting/orientation with virtually any amount of glare, but they are very expensive. The best way to mount a device is generally to the top of the windscreen so the device points directly at you (in terms of yaw and pitch) and pitchwise it cannot reflect the sky. Even a low brightness device can be made acceptable by mounting it the right way.
nje
 Posted 11/07/2011 13:47:27
Too Much Forum
Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)Too Much Forum - (1,815 reputation)
Last Active: 1 minute ago
Posts: 201, Visits: 2,163
Tim, is this device you have referred to the 5 inch unit that has been mentioned before or have you managed to find something a bit bigger?
Thanks for all your work on this
flyingalan
 Posted 11/07/2011 16:05:29
Too Much Forum
165
Tim, thanks for feedback, I'm happy to hear that you have a brighter device coming and I look forward to seeing it. I spoke to Rob at the Sywell show when he showed me a prototype 5 inch device and I told him we had just purchased 2 of your 4 inch devices for our aircraft. If I had known about 5 inch unit being imminent, we would have waited !!!
Anyway very happy with SkyDemon but would like you to consider some upgrade path for those of us already with 4 inch devices to enable us to change to 5 inch.
I don't really want the expense to purchase SD Plan software again when I have recently new valid copies (x2), only need the mobile devices themselves. Maybe we could send our 4 inch units back for exchange so that you don't issue a new licence as such and you just charge present users for the new hardware unit,and some handling, not the software ?? (even if 4 inch unit has minimal value to you).
The alternative is for me to sell our existing units and software to a new user but not clear how new user would stand in regard of your software license ? Can you have a method of transferring ownership maybe ??
Sorry, I know these are messy issues but I'm sure you can expect others to have the same questions and after all it is possibly an additional small revenue stream for you.
regards
 Posted 11/07/2011 17:47:50
SkyDemon Team
The device I'm referring to is the 5" Mobile MD.
It's always regrettable when a new product is launched and a few customers would retrospectively have waited. If we figure out a way of allowing some kind of part-exchange model that doesn't leave us out of pocket, we'll be sure to let you know, but we have no sales channel for second-hand items (or returns) so that makes it rather difficult.
flyingalan
 Posted 11/07/2011 21:22:41
Too Much Forum
165
Tim, yes I realize that the old device has little or no value to you, my only reason for suggesting exchange was so you got the original licence device back and did not run the risk of having both new and old devices out there with active licences and only one paid for. I accept that you need to sell the new hardware for its real cost, I just don't want to be purchasing duplicate software as well.
Maybe you could also comment on whether I am allowed to sell my present systems, software license and hardware, to a new owner ?
I'm not clear what happens if someone purchased my SD mobile hardware device only, and connected it to their valid SD Plan would my device work as licensed device with their software or is my hardware SD mobile device somehow permanently tied to my SD Plan software ?
Hope you can figure something out,
thanks and regards
11/07/2011 21:24:00 by flyingalan
 Posted 12/07/2011 13:18:06
SkyDemon Team
You've correctly identified a complexity that we'll have to come up with a solution for. It's our fault for allowing people with existing Plan subscriptions to purchase a GPS device at reduced cost.
It'll be perfectly possible for you to sell your SD device to somebody, but we'll need to do the license transfer (just ask) and if that person doesn't already have a Plan subscription, they'll need to buy one in order to activate the device. Or, you could sell the whole lot (device and plan subscription) and start afresh. We have no intention of preventing anyone from doing any of these things.
mikesands
 Posted 12/07/2011 14:01:32
Junior Member
Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)Junior Member - (20 reputation)
Last Active: 13/07/2011 15:31:49
Posts: 2, Visits: 10
20
Had another go with my chinese unit at the weekend and had to give up as it was mostly unreadable. We looked at Ordnance survey maps on my iphone next to the chinese thing, and the iphone was very readable. I think the iphone 4 is around 500 NITS. (Do you have the NITS rating for your unit yet?)
Will owners of the software be able to buy just your 5" high brightness unit when it comes out. If so put me down for one now.
Anyone want to buy a crap Chinese 4" ? :-)
denopa
 Posted 12/07/2011 17:59:32
Too Much Forum
Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)Too Much Forum - (172 reputation)
Last Active: 16/03/2012 13:12:48
Posts: 21, Visits: 59
172
Do we have an ETA for the new device?
nje
 Posted 12/07/2011 20:03:22
Too Much Forum
Any idea on price?
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
