jkveenstra
Posted 10/06/2011 22:18:38
Last Active: 10/06/2011 22:07:26
Visits: 32
Does anybody have experience with running the web version on linux (Ubuntu 10). I tried to use it with Firefox and Chrome with the moonlight add-on, but it doesn't work. It shows the circle (loading page), but that's it.
Hopefully someone got it running.
Runways
Posted 11/06/2011 06:42:27
Last Active: 16/05/2013 13:01:14
Visits: 1,439
What a good idea it would be to run SkyDemon on Linux. For the past year I used Windows on my PC solely to download the latest SD onto my mobile device. When this is done, I re-boot in Linux.
Very Newbytheway
DurhamTeaseAirport
Posted 13/06/2011 12:51:45
Last Active: 16/05/2013 14:44:41
Visits: 1,164
I know that people on the Flyer forum are running SkyDemon Mobile under Linux.
Runways
Posted 14/06/2011 05:32:59
Visits: 1,439
Thanks Tim. I have just seen that. I now have wine, winetricks, and SD installed on a Linux (Ubuntu). Any more hints without taking too much of your time? I feel it is an issue with .netCF.
As said, I only boot in windows if I want to plan a route or update SD on my mobile device. Any hints would be greatly appreciated.
Very Newbytheway
DurhamTeaseAirport
14/06/2011 05:34:46 by
Runways
Posted 14/06/2011 08:00:46
Last Active: 2 days ago @ 17:20:59
Visits: 1,562
You are at crossed purposes here.
The thread is about Moonlight - which enables SkyDemon Web to run on Linux boxes in the browser. That certainly works - I've tried it, although it's a bit slow. I believe the next version of Moonlight will support hardware accelerated graphics and this should solve the problem.
What you are talking about is running the Windows version of SkyDemon Plan under Wine which is a completely different kettle of fish.
For the time being, I think you would be better off using virtualisation software and boot your Windows install up inside Linux to use SkyDemon Plan.
VirtualBox is free and works well.
Runways
Posted 14/06/2011 09:27:17
Visits: 1,439
Hello Steve, I was talking about several things at the same time, including mobile SD updating via Linux, if possible, but thank you just the same for the advice.
Very Newbytheway
DurhamTeaseAirport
14/06/2011 09:27:42 by
Runways
Runways
Posted 15/06/2011 05:43:12
Visits: 1,439
VirtualBox worked well, albeit slow. Perhaps rebooting in windows was a little quicker. Please let me know should there be other alternatives to try.
Very Newbytheway
DurhamTeaseAirport
Keithb
Posted 10/03/2012 14:47:18
Last Active: 12/01/2013 15:31:35
Visits: 63
Just worked out how to get Sky Demon running under Linux using wine.
1. create a new environment with wine prefix - see here-
http://wiki.jswindle.com/index.php/Wine_Prefixes
2. Install .Net version 3 SP1, follow instruction here-
http://appdb.winehq.org/objectManager.php?sClass=version&iId=9828
3. use winetricks to install native gdiplus- bash winetricks gdiplus
4. Install the Sky Demon msi.
5.Enjoy!
In theory it should work with .Net version 2 but it didn't want to download the maps when I tried it. I've just started playing with the demo version it and it is impressive, a lot faster than running Moonlight certainly and seems stable so far. I'm currently running Fedora 16.
Keith
Jakob
Posted 13/03/2012 12:45:01
Last Active: 04/02/2013 15:30:27
Visits: 1,582
Keithb (10/03/2012) Just worked out how to get Sky Demon running under Linux using wine.
Hi, I am successfully running SD plan using Wine under FreeBSD (UNIX OS similar to Linux for those unfamiliar with it) I used winetricks to install .Net 2 and GDI+ Even syncing with my mobile device works after a little tweaking of wine. What doesn't work is the simulator/GPS, the window just goes blank. Keith did you get it to work? I even got it working under wine in Mac OS X too.
Microlight pilot from Sweden
Keithb
Posted 13/03/2012 23:13:42
Visits: 63
Jakob (13/03/2012)
[quote] Keithb (10/03/2012)
Hi, I am successfully running SD plan using Wine under FreeBSD (UNIX OS similar to Linux for those unfamiliar with it) I used winetricks to install .Net 2 and GDI+ Even syncing with my mobile device works after a little tweaking of wine. What doesn't work is the simulator/GPS, the window just goes blank. Keith did you get it to work? I even got it working under wine in Mac OS X too. Hi Jakob, I get the blank window running the simulator/GPS too, been trying to find a fix with other winetricks downloads and various native DLLs but have drawn a blank. Also, have you found that if you close the virtual radar and route windows at the bottom you can't open them again? I think that could be related. Keith
