SkyDemon
SkyDemon Forums
Binatone G500
Posted By Steve 14/12/2009 11:47:19
Add to Favorites0
Author Message
Steve
 Posted 14/12/2009 11:47:19
Too Much Forum
Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)Too Much Forum - (63 reputation)
Last Active: 06/12/2011 16:27:58
Posts: 55, Visits: 91
63
Has anyone used or had experiance of this sat nav system (Binatone G500) ?
It has WinCE 5.0 and a big 5 inch display, for only £70 it looks like a bargin, before buying one I would like to know how/if the SkyDemon system will work or not on it.
Any advice or comments very welcome, Steve
Aero AT3-R100, C172 Skyhawk, EGBK Sywell
johnm
 Posted 14/12/2009 15:31:22
Junior Member
Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)Junior Member - (12 reputation)
Last Active: 10/05/2010 16:23:22
Posts: 12, Visits: 23
12
I have run it on a Binatone D430. Unfortunately on the latest release, for some reason the map does not show. My only other reservation is the screen brightness. I have not tried it in the air yet.
http://
 Posted 15/12/2009 11:39:30
SkyDemon Team
Posts: 980, Visits: 630
John, if you contact me directly I can send you a debug build to try and work out why the map isn't showing for you.
Steve
 Posted 16/04/2010 15:42:16
Too Much Forum
63
I have the G500 from Binatone working (ish), all I needed was a registry editor and then to dump the SkyDemon files on the SD card. However all the settings seem to be lost once the system is shut down, it also won't rotate the display, any suggestions guys ?
Steve
PS: microlight fly in at Sywell this weekend, GA-Brooklands fly in next weekend (EGBK)
Steve
 Posted 16/04/2010 15:58:00
Too Much Forum
63
Damn, sorry...... all the regular settings are saved, if you use the software exit menu rather than power off the unit. However the rotate display still does nothing and I really would like to rotate the display into portrait mode, rather than the default landscape, any help guys ?
Steve
 Posted 18/04/2010 14:31:55
SkyDemon Team
If SkyDemon can't rotate the display, it means the device doesn't support display rotation.
Steve
 Posted 21/04/2010 17:32:21
Too Much Forum
63
I have the Binatone G500 working perfectly well now, it's a very cheap device at £90.00 the only thing it won't do is work in portrait mode, everything else is 100% good.
Does anyone know if there is a way to enable the 'Follow Position' mode from loading the program, it's a pain to have to enable it every time the program is loaded, the same applies for the disclaimer, is there a way to stop that appearing every time you power on the device (last one is the hide menu option). All these little things would be a great help to a very polished package.
Steve
 Posted 26/04/2010 21:47:52
SkyDemon Team
Follow mode will become enabled by default in the next version. There's no way to prevent the disclaimer, sorry.
trukkakhan
 Posted 02/05/2010 13:42:39
Junior Member
Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)Junior Member - (23 reputation)
Last Active: 10/12/2011 16:04:49
Posts: 23, Visits: 35
23
My unit - a 4.3" has a main sliding power switch at the back and a "soft" on/off button on the top. If I use the top button to switch off- then on -the unit powers up back to the screen straightaway.
Alex
jimm
 Posted 07/05/2010 14:15:09
Forum Newbie
Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)Forum Newbie - (6 reputation)
Last Active: 18/04/2011 22:41:59
Posts: 6, Visits: 11
6
AT3, do you have any more information on how you got your Binatone G500 working ? I have got all the required files onto the sd card and can't work out how to change the registry or what to change when I get there.
To change the registry on the G500 it seems that I need a remote registry editor but the only one I can find is from Microsoft and only runs within Visual Studio or Platform Builder. And once you manage to get inside the G500s registry what changes are required ?
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
