SkyDemon
SkyDemon Forums
Windows CE 6.0
Posted By daleph 11/12/2009 01:26:42
Add to Favorites0
Author Message
daleph
 Posted 11/12/2009 01:26:42
Forum Newbie
Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)Forum Newbie - (3 reputation)
Last Active: 11/12/2009 15:48:00
Posts: 3, Visits: 3
3
Can you confirm that this works with Win CE 6.0 as it seems not to work at all
When clicking the exe file, nothing happens
Dale
 Posted 11/12/2009 12:09:34
SkyDemon Team
Last Active: 2 days ago @ 16:29:59
Posts: 980, Visits: 630
There's no reason why the software shouldn't run on Windows CE 6.0 providing the prerequisites are there (.net framework) and the device is capable of running arbitrary software.
Perhaps some people will chime in confirming they've managed it.
daleph
 Posted 11/12/2009 14:38:09
Forum Newbie
Posts: 3, Visits: 3
3
Silly question how do I know if it has .net installed?
I cant seem to connect via Win7 as the Mio V735 goes into its own screen and Win7 doesnt see it
I tried to copy over the correct cab from the expanded .net instaler but when clicking it on the unit, i get this is not a valid installer file
Are there any Dll's I can look for to indicate if .Net is installed or not??
As a side note, PocketFMS runs fine fromm the memory card...., does that use .Net?
Dale
P.S I WANT to use YOUR product, its streets ahead........
 Posted 11/12/2009 15:40:55
SkyDemon Team
I don't know what PocketFMS uses.
To install .net compact framework follow the link below. You need to install it while your device is connected by ActiveSync (Windows Mobile Device Center) and then it will install itself on your device too, if you tell it to.
http://www.microsoft.com/DownLoads/details.aspx?familyid=9655156B-356B-4A2C-857C-E62F50AE9A55&displaylang=en
daleph
 Posted 11/12/2009 15:49:59
Forum Newbie
Posts: 3, Visits: 3
3
I cant use Activesync, When the device detects theUSB lead plugged in, it goes into its own animated  'just had a lead plugged in' screen
Activesync there fore doesnt detect the device.
Do you know what files are used on the CE side for activesync? Maybe i could copy them over manually, run activesync by hand?
regards
Dale
 Posted 12/12/2009 20:11:45
SkyDemon Team
No idea I'm afraid.
NorthPole
 Posted 23/12/2009 17:04:42
Junior Member
Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)Junior Member - (11 reputation)
Last Active: 23/12/2009 17:01:04
Posts: 11, Visits: 19
11
I think you need to be connected with Windows Mobile Centre for WINDOWS 7.
I also had to add Net 3.5 for SKyDemon to work with Ipaq 4700hx.
Northpole
rontorbay
 Posted 06/03/2010 14:39:40
Forum Newbie
Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)Forum Newbie - (1 reputation)
Last Active: 06/03/2010 14:37:24
Posts: 1, Visits: 1
1
Inflight works with Windows Mobile 6 BigGrin
Max_UK
 Posted 09/03/2010 09:31:55
Too Much Forum
Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)Too Much Forum - (70 reputation)
Last Active: Yesterday @ 15:30:30
Posts: 56, Visits: 2,142
70
Just to confirm that SkyDemon Inflight will run on WinCE6.
I've recently purchased a WinCE6 (embedded) satnav via ebay (Sold by "Gomallgo").
It doesn't really have a name, but the vendor called it: "A 4.3" Navigator 4GB 2009 Europe Map SpeedCam 128MB SDRAM". (He also has 5" units). Comes with a 4GB SDHC card with iGO8 Europe (a good road satnav prog). Plenty of space left for SKD.
Info for Tim's hardware collectionBigGrin
It has .net 2 ; siRf iv, & a 600 MHz processor. Satellite reception is very sensitive & altitude does not need correcting. Battery life about 2 hours. SkyDemon inFlight runs as well as on any other unit I've tried.
Regards,
Max.
screetch82
 Posted 30/06/2010 18:36:34
Too Much Forum
Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)Too Much Forum - (161 reputation)
Last Active: 12/06/2011 06:32:25
Posts: 111, Visits: 147
161
i am looking at this device: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290378679886&ssPageName=STRK:MEWAX:IT
how do i avoid that the device boots straight into the car nav software? I would like to use it as a normal pda and add skydaemon as a start icon
Using 4.8" WinCe6.0 GPS Touchscreen, NavsGo GO7100 as of March11
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
