Windows CE 6.0
SkyDemon
SkyDemon Forums
Home       Members    Calendar    Who's On
Welcome Guest ( Login | Register )
Windows CE 6.0 Expand / Collapse
Posted 11 December 2009
Forum Newbie
Forum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum NewbieForum Newbie
Last Login: 11 December 2009
Posts: 3, Visits: 3
Can you confirm that this works with Win CE 6.0 as it seems not to work at all
When clicking the exe file, nothing happens
Dale
Post #311
Too Much Forum
Too Much ForumToo Much ForumToo Much ForumToo Much ForumToo Much ForumToo Much ForumToo Much ForumToo Much Forum
Last Login: Today @ 16:50
Posts: 261, Visits: 195
There's no reason why the software shouldn't run on Windows CE 6.0 providing the prerequisites are there (.net framework) and the device is capable of running arbitrary software.
Perhaps some people will chime in confirming they've managed it.
Post #313
Forum Newbie
Posts: 3, Visits: 3
Silly question how do I know if it has .net installed?
I cant seem to connect via Win7 as the Mio V735 goes into its own screen and Win7 doesnt see it
I tried to copy over the correct cab from the expanded .net instaler but when clicking it on the unit, i get this is not a valid installer file
Are there any Dll's I can look for to indicate if .Net is installed or not??
As a side note, PocketFMS runs fine fromm the memory card...., does that use .Net?
Dale
P.S I WANT to use YOUR product, its streets ahead........
Post #314
Too Much Forum
I don't know what PocketFMS uses.
To install .net compact framework follow the link below. You need to install it while your device is connected by ActiveSync (Windows Mobile Device Center) and then it will install itself on your device too, if you tell it to.
http://www.microsoft.com/DownLoads/details.aspx?familyid=9655156B-356B-4A2C-857C-E62F50AE9A55&displaylang=en
Post #315
Forum Newbie
Posts: 3, Visits: 3
I cant use Activesync, When the device detects theUSB lead plugged in, it goes into its own animated  'just had a lead plugged in' screen
Activesync there fore doesnt detect the device.
Do you know what files are used on the CE side for activesync? Maybe i could copy them over manually, run activesync by hand?
regards
Dale
Post #316
Posted 12 December 2009
Too Much Forum
No idea I'm afraid.
Post #317
Posted 23 December 2009
Junior Member
Junior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior MemberJunior Member
Last Login: 23 December 2009
Posts: 11, Visits: 19
I think you need to be connected with Windows Mobile Centre for WINDOWS 7.
I also had to add Net 3.5 for SKyDemon to work with Ipaq 4700hx.
Northpole
Post #330
Posted 06 March 2010
Forum Newbie
Last Login: 06 March 2010
Posts: 1, Visits: 1
Inflight works with Windows Mobile 6
Post #431
Posted 09 March 2010
Junior Member
Last Login: Today @ 16:20
Posts: 17, Visits: 469
Just to confirm that SkyDemon Inflight will run on WinCE6.
I've recently purchased a WinCE6 (embedded) satnav via ebay (Sold by "Gomallgo").
It doesn't really have a name, but the vendor called it: "A 4.3" Navigator 4GB 2009 Europe Map SpeedCam 128MB SDRAM". (He also has 5" units). Comes with a 4GB SDHC card with iGO8 Europe (a good road satnav prog). Plenty of space left for SKD.
Info for Tim's hardware collection
It has .net 2 ; siRf iv, & a 600 MHz processor. Satellite reception is very sensitive & altitude does not need correcting. Battery life about 2 hours. SkyDemon inFlight runs as well as on any other unit I've tried.
Regards,
Max.
Post #435
Posted 30 June 2010
Junior Member
Last Login: Today @ 10:10
Posts: 24, Visits: 40
i am looking at this device: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290378679886&ssPageName=STRK:MEWAX:IT
how do i avoid that the device boots straight into the car nav software? I would like to use it as a normal pda and add skydaemon as a start icon
Using 4.8" WinCe6.0 GPS Touchscreen, occationally Tytn2 WM6.5
Post #676
« Prev Topic | Next Topic »
Reading This Topic Expand / Collapse
Active Users: 0 (0 guests, 0 members, 0 anonymous members)
Forum Moderators: Tim Dawson
Permissions Expand / Collapse
All times are GMT, Time now is 11:49pm
Powered By InstantForum.NET v4.1.4 © 2010
Execution: 0.266. 15 queries. Compression Disabled.
