SkyDemon
SkyDemon Forums
More rotation options?
Posted By stevelup 25/08/2010 12:49:31
Add to Favorites1
Author Message
 Posted 25/08/2010 12:49:31
Too Much Forum
Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)Too Much Forum - (349 reputation)
Last Active: 27/01/2012 17:45:23
Posts: 235, Visits: 585
349
I don't know if this is technically possible, but is there a way of having the 'rotate' function rotate to all four orientations? On my unit, the cables exit from the top of the unit and the display contrast is poorer than it would be if I could use it the other way up.
Cheers,
Steve
 Posted 25/08/2010 16:31:27
SkyDemon Team
SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)SkyDemon Team - (1,247 reputation)
Posts: 980, Visits: 630
It's technically possible but not something we're planning to add to SkyDemon. If you can find another utility to rotate your screen before you start SkyDemon, it should respect that setting (I think).
 Posted 26/08/2010 11:48:23
Too Much Forum
349
Almost!
If I rotate the screen before launching SkyDemon, the splash screen / disclaimer displays correctly.
When you press Continue, a message pops up on the screen 'Rotating Screen' and it puts it back the other way round.
When you exit SkyDemon, the screen rotates back to the original position!
Regards,
Steve
pink leader
 Posted 26/08/2010 15:38:56
Too Much Forum
Posts: 435, Visits: 1,560
710
Some programmes simply keep rotating by 90 degrees when you click "rotate". If thats a generic function, it wd do the trick.
D
 Posted 27/08/2010 09:57:00
SkyDemon Team
It would also annoy the majority of people who just want to flip between the "usual" portrait and landscape orientations.
pink leader
 Posted 29/08/2010 18:30:29
Too Much Forum
710
Fair point D
Similar Topics
Expand / Collapse
Expand / Collapse
Back To Top
